Driver Development Kit (DDK)
Bug in SGLChunklyLink could cause crash if DMA allocation fails
While running a static analysis tool, I came across a bug, which if  hit, would cause a CRASH.
In the constructor tCHInChSGLChunkyLink::tCHInChSGLChunkyLink,
      _linkMemory = _bus->allocDMA(_maxSize);
      if (_linkMemory == NULL)
         status.setCode(kBufferBadMemoryAllocation);
      // Enforce 8-byte alignment for link memory addresses
      if (_linkMemory->getPhysicalAddress() % 8 != 0)
         status.setCode(kBufferBadAlignment);
If the memory could not be allocated, then _linkMemory is dereferenced.
The fix should move the derference inside a  "if (status.isNotFatal )"   check
(7,064 Views)
Hello Kenstern,
I appreciate you letting us know about your findings. I've recorded this in a bug report and we will be investigating the potential issue.
Steven T.
(7,055 Views)
