Driver Development Kit (DDK)
MITE init in Windows driver -- stumped.
Hi, I am writing a Windows WDM driver for the 6503. I have written a function to initalize the MITE, but it does not ssem to work (nothing happens when I write to (remapped with MmMapIoSpace()) BAR1 registers).
Please take a look at this code:
NTSTATUS initMite(IN PCM_RESOURCE_LIST raw,
IN PCM_RESOURCE_LIST translated)
ULONG physicalAddressBAR1 = 0;
PULONG translatedAddressMITE;
PCM_PARTIAL_RESOURCE_LIST list;
PCM_PARTIAL_RESOURCE_DESCRIPTOR resource;
BOOLEAN bar0;
int i, numResources;
size_t len;
/* First: Get BAR1 physical address */
bar0 = TRUE;
list = &raw->List[0].PartialResourceList;
resource = list->PartialDescriptors;
numResources = list->Count;
for (i = 0; i < numResources; i++, resource++) {
if (resource->Type == CmResourceTypeMemory) {
if (bar0 == TRUE) {
bar0 = FALSE;
} else {
[b]physicalAddressBAR1 = resource->u.Memory.Start.LowPart;[/b]
break;
logEventWithDumpData(MSG_PHYS_BAR1, NULL, &physicalAddressBAR1, 1, NULL, 0);
/* Second: Get MITE translated address */
bar0 = TRUE;
list = &translated->List[0].PartialResourceList;
if (bar0 == TRUE) {
bar0 = FALSE;
len = resource->u.Memory.Length;
[b]translatedAddressMITE = (PULONG)MmMapIoSpace(resource->u.Memory.Start,
resource->u.Memory.Length,
MmNonCached);[/b]
if (translatedAddressMITE == NULL) {
logEvent(MSG_MAPPED_NULL, NULL, NULL, 0);
} else {
ULONG data[2] = {(ULONG)translatedAddressMITE, physicalAddressBAR1};
logEventWithDumpData(MSG_INIT_MITE, NULL, data, 2, NULL, 0);
[b]WRITE_REGISTER_ULONG(translatedAddressMITE + 0xc0,
(physicalAddressBAR1 & 0xffffff00L) | 0x80);[/b]
break;
if (translatedAddressMITE != NULL)
MmUnmapIoSpace(translatedAddressMITE, len);
return STATUS_UNSUCCESSFUL;
else
return STATUS_SUCCESS;
What could be going wrong?
(10,424 Views)
Forget about it. It was a stupid pointer arithmetic mistake ((long *)x + y != (char *)x + y) on my behalf 😕
(10,423 Views)
Although this is an old post, can I get similar help?
I used this code to to remap the PCI 6503 addresses, and I also am not getting any result.
I assume the error you experienced is:
   WRITE_REGISTER_ULONG(translatedAddressMITE + 0xc0,(physicalAddressBAR1 & 0xffffff00L) | 0x80);
And it was fixed with this, so the offset is in bytes, not longs :
  WRITE_REGISTER_UCHAR(((unsigned char *)translatedAddressMITE) + 0xc0,(physicalAddressBAR1 & 0xffffff00L) | 0x80);
Then I capture the translated addresses for BAR1 with:
translatedBAR1 = (unsigned char *) MmMapIoSpace(resource->u.Memory.Start,
                resource->u.Memory.Length,MmNonCached);
And try to set PORTA  with WRITE_REGISTER_UCHAR(translatedBAR1 , 0xff  or  0x00 );
But I still don't get any output.  Can you offer any other advice?
-Scotty
(8,150 Views)
