Driver Development Kit (DDK) Programmers
Code support for X series PCIe 6374
Example code for X series that I've downloaded does not seem to support the PXIe 6374 board. In examples (devices.cpp), there is a function getDeviceInfo that looks up an array to match a product ID with the one read from the board (31130, which is the Subsystem ID in output from the QNX pci utility, shown below). I see that the array does not include anything for the 6374 board. It does include other X series devices. The MHDDK code for QNX 6 detects the board at bus number 5, device number 0, which is correct.
I noticed that the date on code files from my very recent download (nixseries.tar.gz) are 2011.
The same applies to code for Windows/Labview RT/RTX. Is there code supporting the 6374 board?
Curiously, the QNX pci utility seems to indicate a PXIe-4353 from device ID, which is also not in the array mentioned. This is the output of the pci utility:
Class = Data Acquisition (Other)
Vendor ID = 1093h, National Instruments
Device ID = c4c4h, PXIe-4353
PCI index = 0h
Class Codes = 118000h
Revision ID = 0h
Bus number = 5
Device number = 0
Function num = 0
Status Reg = 10h
Command Reg = 6h
Header type = 0h Single-function
BIST = 0h Build-in-self-test not supported
Latency Timer = 0h
Cache Line Size= 10h un-cacheable
BAR - 0 [Mem] = ef000000h 32bit length 262144 enabled
Subsystem Vendor ID = 1093h
Subsystem ID = 799ah
Max Lat = 0ns
Min Gnt = 0ns
PCI Int Pin = INT A
Interrupt line = 11
CPU Interrupt = bh
Capabilities Pointer = 50h
Capability ID = 5h - Message Signaled Interrupts
Capabilities = 80h - 0h
Capability ID = 1h - Power Management
Capabilities = 3h - 8h
Capability ID = 10h - PCI Express
Capabilities = 1h - 7e88002h
(5,140 Views)
Accepted by Sorterralee
Add the following line to the devices.cpp :
{ 0x799A, "PCIe-6374", kTrue,  kTrue, 4, 4, kAI_SMIO_Map, 2, kAO_Better1ConnectorMap, 8 }
Works for me.
(5,046 Views)
Thanks. That was my guess. I've been waiting for someone to answer for confirmation.
(5,027 Views)
