08-09-2016 10:57 AM
I need to develop drivers to use my PCIe cards under LabVIEW. The PCIe cards have Adcs and Dacs. I already have C++ libraries for accessing the PCIe cards and I want to build on top of the C++ libraries. I have seen the "Developing LabVIEW Plug and Play Instrument Drivers" article about the Wizard in LabVIEW 8.0, but that assumes that SCPI is used to communicate with the hardware. Should I use the wizard, then replace SCPI commands with calls to a DLL that I develop? Or is there a better approach I should take?
08-09-2016
11:28 AM
- last edited on
12-31-2024
01:44 PM
by
Content Cleaner
Hi John,
You might want to explore the X Series DDK examples for LabVIEW on Linux ( https://forums.ni.com/t5/Linux-Users/Linux-Users-Forum-NIWeek-2012-DAQ-Driver-Demos/td-p/3513356 ) to see one way to connect a C/C++ driver to LabVIEW.
Joe Friedchicken
NI Configuration Based Software Get with your fellow OS users
[ Linux ]Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
08-09-2016 11:39 AM
Hi Joe,
Thanks. I need to support both Windows and Linux. Will your suggested route support both?
08-09-2016
11:52 AM
- last edited on
12-31-2024
01:47 PM
by
Content Cleaner
Yes. There are two different ways:
Joe Friedchicken
08-10-2016
04:36 AM
- last edited on
12-31-2024
01:47 PM
by
Content Cleaner
Thanks. I am developing on Windows at present and do not have a Linux platform today. Are you confirming my approach should be to develop a DLL, not a NI-DAQmx driver? Are there any examples that I can load in Windows that helps me see how I develop the VI's to communicate to the DLL? Or is it just a case of using the same method the Plug & Play Instrument Driver Model shows but replace the SCPI calls with my DLL?
08-10-2016
09:12 AM
- last edited on
12-31-2024
01:48 PM
by
Content Cleaner
Hi John,
Hmmm... Now I'm not sure we're using the same meanings. If you have custom hardware, you cannot extend NI-DAQmx to support it.
Take a closer look at the LabVIEW Example Finder -- you'll see reference designs for nearly every kind of task you can accomplish with the language. To learn about the Call Library Node, navigate to Communicating with External Applications » Using External Code » Integrating DLLs » External Code (DLL) Execution.vi.
Joe Friedchicken
