Driver Development Kit (DDK)
Error on PCI attach device
We have developed a control application using PCI6025E board on QNX. The application works fine on the system we worked with. However, when we test the same application with other systems, we got an error “pci_attach_device: No such device.” We have identified that this error has issued when the function "acquireBoard("PXI0::0::INSTR")" is invoked. All systems have the same setup and configuration. Anybody has ideas about what is happening and how to fix this problem?Thanks a lot,Jean-Guy
(9,439 Views)
Are you able to run lsdaq?  What is the output from it?  It sounds like your system enumerated your board as something other than "PXI0::0::INSTR".  Check on the numbers within that string as it comes from lsdaq to make sure they're both zeros (0).  If they are, then this may be a more challenging problem, but my guess is that the computer enumerated the device in a different way (perhaps because it is in a different slot than the other systems, etc.).
Ed
(9,416 Views)
Dear Ed, Thank you very much for your reply. Yes, we can run lsdaq on all the systems. I am going check the massage. Do you suggest that if the numbers do not match, we should reinstall the board in a different slot? Thanks, Jean-Guy
(9,410 Views)
Hi Jean-Guy,
Rather than trying to coerce your system into enumerating the device to match your program, I would recommend just making your program match your system's configuration.  In a word, just change the string that you give to acquireBoard() to match the string you see in the output from lsdaq.  Let me know if you still have problems after making this change, and recompiling/testing the program.
Ed
(9,408 Views)
Hi Ed,
Actually, I did try to modify the argument in the function acquireBoard() to match the string returned by lsdaq. However, it does work. I will try out again.
Thanks a lot,
Jean-Guy
(9,404 Views)
Sorry. I mean it does not work. Anyway, I will try out again.
Jean-Guy
(9,403 Views)
Hi Ed, The problem has been fixed. The reason is that in the function acquireBoard() (I am using) the bus number and the device number were both hard coded.
Thanks a lot for your help,
Jean-Guy
(9,381 Views)
