Driver Development Kit (DDK)
I want to sync several counters on a PCI-6602
I want to sync several counters using on-board resourses (no external trigger).  Is using the HW_ARM_SEL the best way to do that?
There was a post that explained how to use an external trigger source with the HW_ARM_SEL bits that
yielded an Accepted Solution.  Can you drive the HW_ARM_SEL with an internal signal?  Can this be used across the two TIOs?
Mark Horton
(6,765 Views)
Hi Mark,
To keep all of the HW_ARM_SEL discussion in the same thread, I replied to your other post:
What are the 3-bit field choices for Hw_Arm_Sel in PCI-6601
http://forums.ni.com/ni/board/message?board.id=90&view=by_date_ascending&message.id=1734#M1734
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ] [ macOS ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
(6,733 Views)
