Driver Development Kit (DDK)
EtsSetInterruptFlag in VISA
is there an equivalent vi function in the VISA library so that we can enable/disable interrupts? thanks.
(6,785 Views)
Hi chucky,
The term that NI-VISA uses for an interrupt is 'event'. Since the driver supports many different buses, an interrupt isn't the only asynchronous service request that an instrument can make. Thus, NI-VISA calls these service requests 'events'.
You'll most likely want to use the function pair viEnableEvent() / viDisableEvent() in your program. The VISA Help has more explanation about how to use these functions and even includes a simple C example. In particular, you'll want to read the sections titled "Example of Handling Events" and "VISA Events". If you have further questions about programming with NI-VISA, you'll get a wider audience in the driver's corresponding forum:
http://forums.ni.com/ni/board?board.id=140
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ] [ macOS ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
(6,782 Views)
