Driver Development Kit (DDK)
6230 position measurement
hello,Can anybody give me some examples about how to develop the driver of 6230 of Position Measure.
i want to use the Counter/Timer function of 6230 for Position Measurement.who can help me? thank you.
Message 1 of 14
(12,091 Views)
Hi Jude,
I think you can just measure position using the counters on 6230. You don't need any other driver but DAQmx
https://www.ni.com/en/support/downloads/drivers/download.ni-daq-mx.html
After installing it, you could find some examples in the Example Finder in LabVIEW. Also you can do some prototype work in Measurement & Automation Explorer.
Xu Zheng
帖子被xuzheng在 08-24-2009 01:28 AM
时编辑过了
Message 2 of 14
(12,081 Views)
Thank u  Mr xuzheng, i want to program a RTX program so i need to program a register level driver for 6230,can u give me some help on driver development? thank u for ur reply.
Message 3 of 14
(12,077 Views)
Sorry, Jude. I think all the information I could found is in the MH-DDK webpage: http://sine.ni.com/nips/cds/view/p/lang/en/nid/11737  You would also notice on this page that the DDK is mainly for OEM customers and NI standard phone and e-mail support are not available for NI Measurement Hardware DDK users.
Message 4 of 14
(12,073 Views)
Hi Jude-
This post has some tips for programming a 6229 M Series device for quadrature encoder use.  The information there should also apply to your 6230 (and all other M Series devices).
Hopefully this helps-
Tom W
Message 5 of 14
(12,070 Views)
when this swhen this sentence  "board->G0_Load_A_Registers.writeG0_Load_A(0x00000000);" is excute i cannt use AO function again,can anybody tell me why? entence "board->G0_Load_A_Registers.writeG0_Load_A(0x00000000);" is excute i cannt use AO function again,can anybody tell me why?
Message 6 of 14
(12,049 Views)
Hi Jude-
What specific behavior are you seeing when you say that you cannot use the AO function again?  Is there an AO voltage being generated that stops when you call this function?  In what way do you intend to use the writeG0_Load_A function?
With some more detail on the behavior of the application and the intended use case for the function that appears to be breaking it, we may be able to help you get both subsystems working as you'd expect them to.
Thanks-
Ed
Message 7 of 14
(12,031 Views)
thank u for your reply first,i show the program detail to u to know about more about my problem,i am expecting for ur reply  .
#ifndef ___pci6230_h___
#include "pci6230.h"
#endif
//this main function shows the  sequence of sub function used
main()
Findboard();
initMite();
Button_1.click()//when i click button1 this function excute
	DAC_OUT(0,5);//channel 0- out put 5V
Button_2.click()//when i click button2 this function excute
	DAC_OUT(0,0);//channel 0-out put 0V
//Button_1.click(),Button_2.click(),if i always use this to function i can get the voltage i want.
Button_3.click()//when i click button3 this function excute
myGPCT();;//test
//when i click button3 the program excute Button_3.click().after excute Button_click(),i click button1 or button2,the out put voltage
//keep in the former voltage,i means that before i excute the Button_3.click(),it out put 5v,it keeps,cannt be changed again.untill i  reboot  the windows system.can any boday tell me why.
ShutDown6230();
//Find and initial the board 6230
int Cpci6230::Findboard()
    bus = acquireBoard("PCI1::0xe::INSTR");
    if(bus == NULL)
		return 1;
	//Intitialise Mite Chip.
	this->initMite();
	return 0;
//initial the MITE
void Cpci6230::initMite()
	tAddressSpace  bar0;
	u32 physicalBar1;
	//Skip MITE initialization for PCMCIA boards
	//(which do not have a MITE DMA controller)
	if(!bus->get(kIsPciPxiBus,0)) return;
	bar0 = bus->createAddressSpace(kPCI_BAR0);
	//Get the physical address of the DAQ board
	physicalBar1 = bus->get(kBusAddressPhysical,kPCI_BAR1);
	//Tell the MITE to enable BAR1, where the rest of the board's registers are
	bar0.write32(0xC0, (physicalBar1 & 0xffffff00L) | 0x80);
    //bar1 = bus->createAddressSpace(kPCI_BAR1);
	bus->destroyAddressSpace(bar0);
//shut down the board 6230
int Cpci6230::ShutDown6230()
    //bus->destroyAddressSpace(bar1);
	releaseBoard(bus);
	return 0;
void Cpci6230::test()
    u32 serialNumber;
    serialNumReadMSeries(bus, &serialNumber);
    printf ("Serial Number: 0x%08X\n", serialNumber);
//Output a voltage signal to chanel,The scaled part was changed,i still don't understand the Eeorom operation~
void Cpci6230::DAC_OUT(int channel,float voltage)
	//  read eeprom for calibration information
	/*   const u32 kEepromSize = 1024;
	u8 eepromMemory[kEepromSize];
	eepromReadMSeries (bus, eepromMemory, kEepromSize); */
	// create register map
    tAddressSpace  bar1;
    tMSeries *board_tMSeries;
    board_tMSeries = new tMSeries(bar1);
    // ---- AO Reset ----
    configureTimebase (board_tMSeries);
    pllReset (board_tMSeries);
    analogTriggerReset (board_tMSeries);
    aoReset (board_tMSeries);
    aoPersonalize (board_tMSeries);
    aoResetWaveformChannels (board_tMSeries);
    aoClearFifo (board_tMSeries);
    // unground AO reference
    board_tMSeries->AO_Calibration.writeAO_RefGround (kFalse);
    // ---- End of AO Reset ----
    // ---- Start A0 task ---
   /* tScalingCoefficients scale;
    aoGetScalingCoefficients (eepromMemory, 0, 0, channel, &scale); */
    aoConfigureDAC (board_tMSeries,
                     channel,
                     0xF,
                     tMSeries::tAO_Config_Bank::kAO_DAC_PolarityBipolar,
                     tMSeries::tAO_Config_Bank::kAO_Update_ModeImmediate);
    // ---- Write to DAC ----
    i32 value;
    //aoLinearScaler (&value, &voltage, &scale);
	value=(voltage/10.0)*32768;
    //printf ("voltage: %f (%d)\n", voltage, value);
    board_tMSeries->DAC_Direct_Data[channel].writeRegister (value);//value
    // ---- Stop ----
    // cleanup
    delete board_tMSeries;
    return;
void Cpci6230::testt()
	cardSpace = bus->createAddressSpace(kPCI_BAR1);
	board_tTIO = new tTIO(cardSpace);
	board_tTIO->G01_Joint_Reset_Register.writeG0_Reset(1);
	board_tTIO->G0_Command_Register.writeG0_Disarm(1);
	board_tTIO->G0_Load_A_Registers.writeG0_Load_A(0x00000000);
	board_tTIO->G0_Command_Register.readG0_Disarm();
	delete board_tTIO;
	bus->destroyAddressSpace(cardSpace);
//Counter test
void Cpci6230::myGPCT(void)
	tAddressSpace  cardSpace;
	tTIO *board;
	board = new tTIO(cardSpace);
	//Reset
	board->G01_Joint_Reset_Register.writeG0_Reset(1);
	//Disarm
	board->G0_Command_Register.writeG0_Disarm(1);
	//load initial value of 0
	board->G0_Command_Register.writeG0_Load(1);
	//set the counting mode to quadrature encoding X4
	board->G0_Counting_Mode_Register.setG0_Encoder_Counting_Mode(3);
	board->G0_Counting_Mode_Register.writeG0_Index_Phase(3);
	//set source to the internal timebase (20 MHz)
	board->G0_Input_Select_Register.writeG0_Source_Select(0);
	//set gate
	board->G0_Input_Select_Register.writeG0_Gate_Select(2);
	board->G0_Mode_Register.writeG0_Gate_Polarity(0);
	board->G0_Mode_Register.writeG0_Gating_Mode(2);
	board->G0_Mode_Register.writeG0_Trigger_Mode_For_Edge_Gate(3);
	//set counting direction to Gate IO connector
	board->G0_Command_Register.writeG0_Up_Down(2);
	//arm counter
	printf("counter value is 0x%08lx\n",
			board->G0_Save_Registers.readRegister());
	board->G0_Command_Register.writeG0_Arm(1);
	//delay long enough for the quadrature encoder to turn a few times
		long int i,j;
		printf("waiting...\n");
		for(i=0;i<10;i++)
			for(j=0;j<30;j++)
	//read counter value
	//Use this method to read the value of an armed counter
	//during non-buffered counting.  Since the value of the counter may
	//change during the read, we make sure that the value is stable.
	unsigned long counterValue1, counterValue2;
	counterValue1 = board->G0_Save_Registers.readRegister();
	counterValue2 = board->G0_Save_Registers.readRegister();
	if(counterValue1 != counterValue2)
	printf("counter value is now 0x%08lx\n",counterValue1);
	//Disarm
	delete board;
Message 8 of 14
(12,025 Views)
hi Ed W
i want to use 6230 AO function to out put a voltage,and also use the Position Measurement function of GPCT to get the feed back of system from the position sensor (it haves A,B signal).
thank u for ur help.
Message 9 of 14
(12,024 Views)
Thanks, Jude.  I'm currently looking into the problem, but I have some side questions for you in the mean time.  It's clear that you're using Windows - what version are you using, and why did you decide to use the driver development kit?  The only reason I ask is that NI-DAQmx will allow you to write software to control and measure with your 6230 without requiring you to develop custom driver.  Let me know, and I'll get back to you on the position measurement problem that you're having as soon as I can.
Thanks again,
Ed
Message 10 of 14
(12,013 Views)
