Driver Development Kit (DDK)
6230 position measurement
hi Ed,i want to develop a realtime test platform using RTX,so i should to use DDK of ni card,i am using Microsoft Visual Stdio2005 to develop my program now.
thank u for ur reply.
Message 11 of 14
(5,320 Views)
Accepted by topic author jude.xu
Hi Jude,
What example did you use as a basis for your counter configuration? It looks like you may have overlooked the advice in the thread that Tom pointed out.
In addition, I'm wondering if your method "Cpci6230::myGPCT()" is the entirety of the code you use to configure and read from the counter. If it is, then you're missing a call to tTIO::setAddressOffset() and any subsequent register I/O will be directed at the wrong addresses. This could be the reason why AO updates cease after calling Cpci6230::myGPCT() -- by configuring the counter using the wrong register addresses, the board has entered an unknown or unstable state.
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ] [ macOS ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
Message 12 of 14
(5,293 Views)
Thank u Joe F. i will try again. thank u for the reply.
Message 13 of 14
(5,259 Views)
thanks,  Joe F. i think your advice is right, it works finally,thank u so much.
Message 14 of 14
(5,245 Views)
