Driver Development Kit (DDK)
FF answer for Register ID PXI 6509
Hi All,
I am using register level programming to program my PXI 6509. I am using a chassis with a PXI 8106 controller.
I manage to initialize the device, to read the manufacturer ID and the model. But when I reads the ID Register, I always get the answer "FF". Moreover, when I configure the P0 port for output and tries to update the value of the port to 1, the outputs are not at the value 5V.
I have linked my C code (I am using CVI).
Do you have any idea why I am getting the answer "FF"? Why are the values of the outputs not changing?
Many thanks in advance for your help,
Charlotte
(6,418 Views)
Please see my reply here -- http://forums.ni.com/t5/Driver-Development-Kit-DDK/FF-answer-for-Register-ID-PXI-6509/m-p/1211487#M1...
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ] [ macOS ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
(6,346 Views)
