Driver Development Kit (DDK)
FF answer for Register ID PXI 6509.
Hi All,
I am using register level programming to program my PXI 6509. I am using a chassis with a PXI 8106 controller.
I manage to initialize the device, to read the manufacturer ID and the model. But when I reads the ID Register, I always get the answer "FF". Moreover, when I configure the P0 port for output and tries to update the value of the port to 1, the outputs are not at the value 5V.
I have linked my C code (I am using CVI).
Do you have any idea why I am getting the answer "FF"? Why are the values of the outputs not changing?
Many thanks in advance for your help,
Fabien PLOT
(6,334 Views)
Hi Fabien,
It appears as though you aren't correctly initializing the MITE. Have you tried using the DDK examples [1]? If your system or software architecture prevents you from using them, you can at least refer to them for a model of how and when to write to the registers.
[1] RLP for OEM Customers
http://digital.ni.com/express.nsf/bycode/exyv4w?opendocument&lang=en&node=seminar_US
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ] [ macOS ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
(6,302 Views)
