Driver Development Kit (DDK)
New M Series DDK Example: Retriggerable Finite Pulse Train Generation
This example demonstrates how to configure the two counters on an M Series board to generate a finite pulse train with a digital edge start trigger. The counters are set to be retriggerable so that the hardware does not need to be reprogrammed between pulse train generations: new start trigger edge will cause the pulse train to be generated again.
Use this example to add retriggerable finite AI and AO operations to your driver.
Please let me know if you have questions or problems. Thanks 🙂
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ] [ macOS ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
Message 1 of 1
(7,230 Views)
