Driver Development Kit (DDK)
PXI-6133+Measurement Hardware DDK: Binary data when input voltage exceeds the input range
Hi there,
a colleague is using the NI Measurement Hardware DDK (Driver Development Kit) and a PXI-6133.
He reads out the binary data and is wondering about the converted value. With an selected input range of +-1.25 V and a slight higher input-voltage (1,6 ... 1,8 V) the converted value is over 12 V.
His questions are:
 - Which binary value do I get when the input voltage exeeds the Maximum or the Minimum of the input range?
 - Is there a limit when exeeded the binary value jumps to a "emergency-value" (like a clipping)
Thank you very much for your help.
With best regards,
Ralf N.
(7,258 Views)
Hi there,
a Happy New Year!  Smiley Very Happy
Any news?
Ralf N.
(7,190 Views)
Hi Ralf,
Happy New Year indeed 😄 Let's see if we can figure out what's going on.
The first questions I have are about your colleague's program:
  1. Is he using one of the S Series examples from the DDK? If so, which one?
  2. How does he convert from the ADC's raw codes to Volts?
  3. When applying out-of-range voltages to the board, what binary values does he read?
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ] [ macOS ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
(7,159 Views)
