Driver Development Kit (DDK)
question about MHDDK
there r a lot of expression like the follow in the GPCT example 1:
 board_tTIO_gpct->G0_Mode_Register.setG0_Output_Mode(tTIO::tG0_Mode_Register::kG0_Output_ModePulse);
    board_tTIO_gpct->G0_Mode_Register.setG0_Loading_On_Gate(tTIO::tG0_Mode_Register::kG0_Loading_On_GateNo_Reload);
    board_tTIO_gpct->G0_Mode_Register.setG0_Loading_On_TC(tTIO::tG0_Mode_Register::kG0_Loading_On_TCRollover_On_TC);
but in my program i cannt find the defination of :"tTIO::tG0_Mode_Register::kG0_Output_ModePulse" and "tTIO::tG0_Mode_Register::kG0_Loading_On_GateNo_Reload". a lot of the defination is not found in my program  can any body tell me why?
 I had explored the tTIO.h ,but i still didn't found any defination of them.
thank u
(8,178 Views)
Both constants should be defined in tTIO.h.  The definitions are as follows.
tTIO.h, line 910
kG0_Output_ModePulse             = 1
tTIO.h, line 953
kG0_Loading_On_GateNo_Reload         = 0
Let us know if you still have problems.
Ed
(8,168 Views)
thank u so much Ed-W
can u give me the tTIO.h u used.i really cannt find the defination of them and a lot another like them.
i am waiting for ur reply.
thank u  again for ur kindly help.
(8,147 Views)
The tTIO.h file that I'm using comes from the nimseries/ChipObjects folder.  You can download the M Series register maps and examples from the Register Level Programming website.
(8,138 Views)
thank you Ed W , i will try it.i think i used the wrong tTIo.h .my friend give me the ni660x DDK.
(8,114 Views)
