Driver Development Kit (DDK)
daqcard 700 driver
We used daqcard 700 and labview5.1 on mac os. But the mac was out of order. Can we use this card under the pc windows xp? which driver we can  use? Tks
(7,855 Views)
You should use the NI-DAQ traditionnal until version 6.9.x.  The DAQCard 700 is no longer supported in next versions. You will find the driver on all versions multifunction DAQ driver page. Check if the current version of LabVIEW you are using is supported by the driver you will install.
Cordially,
Message Edité par Mathieu R. le 10-27-2006 03:28 PM
(7,847 Views)
