10-25-2006 11:08 AM
10-27-2006
08:26 AM
- last edited on
05-20-2025
01:35 PM
by
Content Cleaner
You should use the NI-DAQ traditionnal until version 6.9.x. The DAQCard 700 is no longer supported in next versions. You will find the driver on all versions multifunction DAQ driver page. Check if the current version of LabVIEW you are using is supported by the driver you will install.
Cordially,
Message Edité par Mathieu R. le 10-27-2006 03:28 PM
