Driver Development Kit (DDK)
Showing results forĀ
Search instead forĀ
Did you mean:Ā
register level programming
Our laboratory is treating the precision control in Rtx foundation.
We try to manage the 6703card in a Rtx foundation.
So, we have to program a register level programming.
We know the 6703card that use Window address.
But I don't know using window address well.
Therefore, I can not use the card.
Is the thing usual to use Window address on DAC card?
Is it valuable to invest the time to learn it?
Can I take the manual about it?
I thank for reading though my English is too short.
p.s. We read the reply well. But I think that NI-DAQmx is not suitable.
(9,139 Views)
Thanks for contacting National Instruments,
To make matters easier, you will not need to write your own register level program because we have created an NI-DAQmx Base driver for RTX. You can find it here
Post a reply if you have any further questions.
Jordan Randall
National Instruments Italy
(9,126 Views)
As it turns out, I'm guessing that NI-DAQmx Base will not work for you.  It does not support the 6704 nor does it have a C interface (LabVIEW RT for RTX only).  The best option would be to use a 671x or 673x since we have MHDDK examples for those boards on the web.  The MHDDK isolates you from having to write your on driver for your OS. We have a beta of the RTX bus interface which I can post if you are able to move to a different AO device.
(9,093 Views)
Is it impossible to operate my system just the rtx with C++ if I use the NI-DAQmx base 2.0?
(9,049 Views)
No, NI-DAQmx Base 2.0 for RTX supports the LabVIEW API only.
-Alan A.
(8,998 Views)
