‎10-24-2006 02:43 PM
‎10-25-2006
06:17 PM
- last edited on
‎05-30-2025
03:05 PM
by
Content Cleaner
Hi Troy,
I would not consider this expected behavior, please tell me more about the problem. Is the data that you are receiving correct? If it is correct this sounds like the delay is in the PCI bus with either sending commands or retrieving data. How many PCI devices do you have in this system? If the data is incorrect then perhaps there is an issue with the synchronization signals themselves (Sample Clock Timebase, Synch Pulse, and AI Start Trigger).
Also since DAQmx 8.0, you can make multidevice tasks with DSA devices. This means that you can make one task, and include multiple devices in the channel list. DAQmx will take care of all synchronization routing for you.
Multdevice Task Support For DSA and SMIO
Try it out (if you are not already) and let me know if it makes any difference.
Best Regards,
Jeff Tipps
‎10-26-2006 07:40 AM
Hi Jeff,
Thanks very much for your reply. Interestingly the behaviour (~8sec delay) seems to have gone away. I believe your assessment is correct. I am using a Magma PCI expansion bus with my laptop and I think the issue may have been there. Last night when I restarted everything, the delay no longer occurred. Hopefully, it has resolved itself.
Thanks again for the help,
Troy
‎04-07-2007 01:24 AM
‎04-09-2007 01:53 PM
‎04-09-2007
02:00 PM
- last edited on
‎05-30-2025
03:05 PM
by
Content Cleaner
I'm having problems with the PXI-bus. I'm using an 8-slot 1042Q chassis, and I have problems when trying to use slots 5&6 together, or slots 7&8 together. With outher slot combinations, I can stream all 4 channels from each of two PXI-6120 boards at 800Khz sample rate. See the following thread for more info:
https://forums.ni.com/t5/PXI/Streaming-from-multiple-devices-fails-if-in-certain-slots/m-p/503566
