Dynamic Signal Acquisition
Advanced:Hardware Compare:Samples Compared
I want to get the output of the HSDIOInstrument HardwareCompare result for both fail and pass bits. How can i do that?
(6,323 Views)
Have you checked out this white paper?
http://www.ni.com/white-paper/7281/en/
Michael Keane
(6,293 Views)
Thank you Michael. But I was looking for the positon(cycle#) where I start to compare the output and end to compare the output. My goal is to know all the cycle # where I have compare statement (H or L) whether it fail or passes. I am getting an output, but it includes all the data where I don't have compare statements.
(6,285 Views)
Hi etho,
Is the SupportedDataStates property node set to L,H,X (resp only?)
Is the "Hardware Compare - Response Only" example similar to what you are looking for?  This is in the Example Finder at Hardware Input and Output >> Modular Instruments >> NI-HSDIO >> Dynamic Acquisition
Michael Keane
(6,272 Views)
