Dynamic Signal Acquisition
Boolean Reference Array
How does one create a boolean reference array?
Steve
(8,015 Views)
Accepted by topic author 4BoysDad
Hi 4BoysDad,
Are you wanting to create an array of booleans in LabVIEW?
If so, you can place an array constant down, then place a boolean constant inside the empty array. This will turn it into an array of boolean data type. Then you can stretch the array out to add/remove the number of elements in the array (or use the up/down index arrows).
If you are trying to do this in something other than LabVIEW, let me know.
Also, for future reference your post will get more action if you post it in the correct subforum. This forum is for our DSA hardware, posting in the LabVIEW forum will result in faster answers.
Micah M.
NIC AE Specialist - Test
(8,009 Views)
Micah;
I have the array created
Now what I want to do is coninuously monitor this 8 switch 1D array (Boolean array) for changes i.e. any changes in the switch positions. I also would like to clear these switches on Stop.
Any suggestions?
Steve
(8,005 Views)
Hi 4BoysDad,
I have a suggestion for the "clear switches on Stop". Create a local variable of the boolean indicator and insert a select as shown in the image below:
This seems to be a LabVIEW question, and as Micah mentioned it would be better if you posted your request in the LabVIEW forum. You would get faster replies.
Best Regards,
Jignesh P
Best Regards,
Jignesh Patel
Principal RF Software Engineer
(7,977 Views)
thank you
(7,970 Views)
