Dynamic Signal Acquisition
NI 9234
How do you set up multiple NI 9234 USB units for master/slave mode in Dasylab v11
(7,443 Views)
David-
I would recommend that you repost your question on the DASYLab forum found here: http://forums.ni.com/t5/DASYLab/bd-p/50 .  This way, you will have visibility to DASYLab users/enthusiasts.
Sean
Applications Engineering Specialist - Semiconductor Test
(7,434 Views)
Sean,
I don't think that the issue is DASYLab.
Can you configure two USB based NI 9234 to master/slave synchronization? How do you configure the tasks to do that?
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(7,424 Views)
It is not possible to synchronize two USB-9234s.  The USB sleeve hardware does not support it.
9234 modules can be synchronized with cDAQ or cRIO, but not with the USB sleeves.
-alan
(7,421 Views)
Good call. I overlooked the fact that it was USB.
(7,416 Views)
