Dynamic Signal Acquisition
Can I enable ICP circuitry for a channel in DAQ Assistance?
I would like to know if it's possible to use the DAQ Assistance in LabView 7.1 to enable ICP circuitry for a channel.
(6,336 Views)
Yes, it is possible. The Sound Pressure and Accelerometer measurement types allow you to enable IEPE through the DAQ Assistant. These measurement types are also AC coupled while the voltage measurement is DC coupled by default. I would recommend using the one which is related to the type of sensor that you are actually using since these measurement types also include scaling to engineering units.
Also, here's a KB which talks about IEPE in DAQmx:
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/3ad6cce935192b4086256f6b0079cb1f?OpenDocument
You might find some other useful links on the DSA Support site at:
http://www.ni.com/support/dsa/
Hope this helps,
Jack
(6,325 Views)
