Dynamic Signal Acquisition
DAQ assistant
I would like to use DAQ assistant for sine signal generation. when i use DAQ assistant and drop it in block diagram. after initialization of this assistant, when i select analog output (current or voltage). this assistant does not detect/find the hardware board.
i am using AT-MIO-16XE-50. why it is like this?
(6,465 Views)
The reason that the DAQmx Assistant does not recognize the AT-MIO-16XE-50 is because that board is not supported in DAQmx. All of the AT boards will only be supported with Traditional NI-DAQ. I would recommend looking at some of the Traditional NI-DAQ analog output examples in order to get started.
Also, if you would like to see a list of all the boards supported under DAQmx, check out the NI-DAQ readme file which comes with each version of the driver. If you already have it installed, it should be here: C:\Program Files\National Instruments\NI-DAQ\readme.html.
Hope this clears this up.
Jack
(6,465 Views)
