Dynamic Signal Acquisition
Excel Addon for TDMS Files
Why is there a "NI_ChannelName" field (column H) when it is duplicate of the channel Label in column A?
(8,181 Views)
Did you use NI-DAQ to create the .tdms file?
According to https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/functions/set-waveform-attribute.html, the waveform attribute "NI_ChannelName" is set by NI-DAQ.
(8,166 Views)
that is great and thank you for your reply.
Why is it even there?  when would it ever be different than the channel name?
thank you in advance
(8,142 Views)
Accepted by longwalker
longwalker,
You could change "name" to whatever you want, but you should not change "NI_ChannelName" because it is only used by and for NI-DAQ to mark the name of the virtual channel producing the waveform.
(8,136 Views)
