Dynamic Signal Acquisition
Excel Addon for TDMS Files
Why is there a "NI_ChannelName" field (column H) when it is duplicate of the channel Label in column A?
(8,271 Views)
Did you use NI-DAQ to create the .tdms file?
According to https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/functions/set-waveform-attribute.html, the waveform attribute "NI_ChannelName" is set by NI-DAQ.
(8,256 Views)
that is great and thank you for your reply.
Why is it even there?  when would it ever be different than the channel name?
thank you in advance
(8,232 Views)
Accepted by topic author longwalker
longwalker,
You could change "name" to whatever you want, but you should not change "NI_ChannelName" because it is only used by and for NI-DAQ to mark the name of the virtual channel producing the waveform.
(8,226 Views)
