Dynamic Signal Acquisition
Frequency reponse is not the same when the test is repeated
Hi.
I am using NI PCI 4551 card for my Frequency Response analyser.I am using swept sine analyser method .The sweep frequencies are from 0.1 Hz to 10Hz.
The result is not the same when run repeatedly with the same UUT for frequency range from 0.1 Hz to 0.5Hz. So the initial value is varying and could not find the 3dB point accuartely.
Plaese suggest me what would be the reason and how can I eliminate
thank you
(6,413 Views)
What you are seeing is probably due to your UUT and the method you are using. Beginning at a different frequency looks like it is changing the response of your system.
What swept sine analysis are you doing (toolkit, environment, board, etc.)? If you try outputting sine waves at stepped static frequencies, you may be able to allow the system to come to equilibrium before moving on to the next analysis. You could use the test panels of your output board to generate a static sine wave then measure the response and wait for an equilibrium.
(6,413 Views)
