Dynamic Signal Acquisition
High speed data collection using ethernet, PXI-8186 and PXI-6115
I have a PXI-1042 chassis with a PXI-8186 Embedded Controller and a PXI-6115 I/O card installed.  Is it possible to use this setup for high speed data acquisition connected to a laptop running LabVIEW using the ethernet port on the PXI-8186?
Thanks for the help!
Matt
(6,475 Views)
Hi Matt,
What rates are you targeting?  According to the specifications page the max sampling rate is 10 MS/s. Is that fast enough?
Perry S.
(6,467 Views)
Hi Perry,
The PXI-6115 is the one piece of this puzzle that I'm 100% confident in.  I've been using a PCI-6115 card for the last five or so years and it's plenty fast enough for what I need it for.
What's completely foreign to me as a mechanical engineer is how to communicate back and forth with the PXI-1042 chassis through the ethernet port on the PXI-8186.  I'm not finding much in the way of documentation or examples doing something similar.
Any help would be very much appreciated.
Matt
(6,463 Views)
Consider adapting the following cRIO reference design for your PXI applicaiton.  You will need to substitute in DAQmx calls for our RT Controller cRIO VIs.
https://forums.ni.com/t5/Example-Code/Embedded-High-Speed-Data-Logger-Reference-Design/ta-p/3996474
Preston
Preston Johnson
Solutions Manager, Industrial IoT: Condition Monitoring and Predictive Analytics
cbt
512 431 2371
preston.johnson@cbtechinc
(6,461 Views)
