Dynamic Signal Acquisition
How can I configure IMAQ PCI-1424? Can the settings in the properties be modifed?
I have installed PCI-1424 and NI-IMAQ 2.5.How can I configure IMAQ-1424?Can the settings in the properties of "IMAQ PCI-1424:img x" or "Channel x "be modified?When I creat a new virtual channel,in the step of "channel wizard" ,why PCI-1424 doesn't imerge ,only in the selected item?
(6,510 Views)
The "Channel Wizard" is not for IMAQ devices, so that is why it does not show up in that window. Also, the properties of the channel of the PCI-1424 is determined by the camera file which is loaded. Since all cameras are different, the properties which show up for each camera will also be different.
Hope this clears some things up,
Jack Arnold
Application Engineer
(6,510 Views)
