Dynamic Signal Acquisition
My NIDSA-4552, intermittant at first, appears to have failed
I have used the NIDSA-4552 out of LabVIEW for a while, and it would occaisionally hang during a long run (a couple of hours). Sometimes, I could exit LabVIEW and test and run the card from MAX. If this didn't work, I could shut down and restart, and everything would work again. Now, however, if I use MAX, the test panel will come up, there are no resource conflicts, but it hangs the system when I try to acquire. If i use LabVIEW, the system hangs on initialization of the card. I am runing LabVIEW 6.0.2, NI-DAQ 6.9.2f8, and NI-DSA 1.11 under Windows 2K
(6,631 Views)
Dear Sir,
Thank you for using NI Developer Zone.
I am posting a new version of the NI-DSA driver version 1.2 in our ftp site: ftp://ftp.ni.com/incoming/nidsa12.zip
I believe that you have a card that needs to be repaired but before calling in to request a RMA, I suggest you to install NI-DAQ 6.9.2 and NI-DSA 1.2 in another computer in order to verify if the same problem persists in a different PC.
If this test results fruitless, please call the NI technical support number in order to receive direct assistance by one of our applications engineers.
Best Regards,
Omar De Andrade - Computer Based Instruments
(6,631 Views)
I tried the card in another PC, and it worked fine. I moved it back to th original machine, it sampled once, then hung.
I am now pursuing the solution via phone, but thanks for your help.
(6,631 Views)
