Dynamic Signal Acquisition
How do I change the gain setting on the ni-6052E daq PCI card?
I am using windows 2000 on my computer.
(7,015 Views)
Jose;
If you are using Labview to program the board, you can set low and high input limits at the AI Config.VI. That will make Labview select the best gain for the board which matches the correspondent limits you chose.
Hope this helps.
Filipe
(7,015 Views)
Thanks Filipe. This solution worked great.
Jose 🙂
(7,015 Views)
I want know, what function on labwindows CVI 5.5 allow to change the gain of DAQcard1200,
My software is Windows XP.
thanks
(7,015 Views)
