Home
Community
Discussion Forums
Additional NI Product Boards
Dynamic Signal Acquisition
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
How do I change the gain setting on the ni-6052E daq PCI card?
jose
Member
12-11-2001
10:24 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I am using windows 2000 on my computer.
0
Kudos
Message
1
of 4
(6,983 Views)
Reply
Re: How do I change the gain setting on the ni-6052E daq PCI card?
Filipe A.
Active Participant
12-12-2001
09:14 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Jose;
If you are using Labview to program the board, you can set low and high input limits at the AI Config.VI. That will make Labview select the best gain for the board which matches the correspondent limits you chose.
Hope this helps.
Filipe
1
Kudo
Message
2
of 4
(6,983 Views)
Reply
jose
Member
Author
12-12-2001
09:37 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Thanks Filipe. This solution worked great.
Jose
0
Kudos
Message
3
of 4
(6,983 Views)
Reply
gourli
Member
04-13-2004
08:15 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
I want know, what function on labwindows CVI 5.5 allow to change the gain of DAQcard1200,
My software is Windows XP.
thanks
0
Kudos
Message
4
of 4
(6,983 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
