Dynamic Signal Acquisition
How do I dynamically link in analysis functions at runtime?
I think I remember a LabVIEW training exercise where that showed a compiled VI where the user could select from a list of analysis functions and apply that function to captured data. I remember that the functions were all contained in a specific directory. Then you could add new functions at runtime by adding them to the appropriate directory even, after the LabVIEW application was compiled into a *.exe file.
The problem--I can't find this training exercise anywhere and can't remember enough details to recreate it. Can anyone point me in the right direction?
(6,846 Views)
It is not very what you mean here. But I can guide you to the Analysis VI.
It is Program Files/National Instruments/Labview 6/vi.lib/Analysis
This folder contains a set of Analysis related LLBs.
Regarding the user selecting the type of Analysis during run time, you can get it either by using a ring menu and a corresponding case structure in the block diagram.
You can take a look at the examples on Ring menu Control.
Please let me know if this helps.
(6,846 Views)
OK, I finally figured this one out (shortly after NI support told me it couldn't be done in LabVIEW.) You can use VI Server calls to call a VI using the "Call by Reference Node" function. First I use a "List Directory" function to determine what VIs are in a specific directory. Then I wire that list into the strings of a menu ring. Then when the user selects a specific filter, I use "Build Path" and "Open Reference" functions to dynamically call the selected VI. The filter VIs can be added at any time, even if the calling VI is compiled as a *.exe file. I'll post the VI's to this thread later. Note that the reference that got me started towards a solution was an article in LabVIEW Technical Resource, Volume 6, No. 4 on VI Server applications. www.ltrp
ub.com
(6,846 Views)
