Dynamic Signal Acquisition
How do we acquire data on the AI channels of the DSA NI PCI4551 using NIDSA APIs?
We have easily been able to achieve analog outptut using the NI4551. However there is a problem in achieving analog input using NIDSA_read_scan_channel which gives an output of a buffer having all zeroes if timeout is given as 0.0 secs and hangs for any other(including default) timeout values.
(6,590 Views)
VEMFRA,
I do not see a function called NIDSA_read_scan_channel in the NI-DSA Help for C Programmers. It also does not come up in a search of NI's support site. Where did you find a reference to this function?
<-*DrkOvrlord*->
(6,588 Views)
DrkOvrlord
It came on the CD with the card. The library of APIs for C programming are listed in the DSA manual. You are right about not finding anything on NIs(non)support site.
(6,589 Views)
