Dynamic Signal Acquisition
PXI 4472 and MIO Analog Input Synchronization
My System : PXI-8186, PXI-4472 1EA, PXI-6071E 2EA, LabVIEW 7.1, NI-DAQmx 7.2
I want 4472 and 6071E AI Synchronization using DAQmx version... like http://sine.ni.com/apps/we/niepd_web_display.DISPLAY_EPD4?p_guid=B8C1DA7151524E2EE034080020E74861&p_node=DZ52007&p_submitted=N&p_rank=&p_answer=&p_source=External
I try to this method using \examples\DAQmx\Synchronization\Multi-Device.llb
But don't success by serival error.
Please DSA and MIO synchronization using DAQmx version.
Thanks..
(6,385 Views)
There currently is not an example using NI-DAQmx that synchronizes an MIO board with a DSA device. Is there a reason why you have to use DAQmx for this? The 4472 and 6071E are both Traditional and NI-DAQmx devices. Good luck.
Best Regards,
Jeremy R.
NI - Applications Engineer.
(6,385 Views)
