Dynamic Signal Acquisition
How to get raw ADD counts
I have a NI9234 and would like to get the raw ADD counts. Is this possible to do without reversing the scaling?
Jim
(7,336 Views)
Sure,
Just read "Unscaled" or read "Raw".  Change the DAQmx read VI to either one of these to get unscaled data. (Raw is under "More")
Check out this example VI http://sine.ni.com/devzone/cda/epd/p/id/1611
-gaving
(7,335 Views)
Thanks for the reply, unfortunately I am using Measurement Studio 8.1
It does sound like what I am looking for, the actual count from the AD. As I am using a 24 bit AD I would expect to have an Int32 holding the count for each sample.
Jim
(7,312 Views)
http://forums.ni.com/ni/board/message?board.id=232&message.id=7172&requireLogin=False
I think this person wanted to do the same thing.  The raw codes should be unsigned 32, I believe.  It's  pretty much the same thing as LabVIEW, just using a different version of the read command.
-gaving
(7,294 Views)
