Dynamic Signal Acquisition
same device multiple channel acqusition at different sample rate
Hi
I want to acquire signal from NI 9219 from two (or more) channel simoultaneously, at different sample rate for each channel.
Meaning
Channel 1: sample rate = 1kHz
Channel 2 sample rate = 100kHz
Channel 3  samplr rate = 50 kHz
all to be acquired simoutaneously.
Please help
Thnx
Ravinder
(7,028 Views)
Normally you would be able to do so with the NI 9219 module (with diferent sample rates), but not with the particular sample rates that you want.
The 9219 can handle simultaneous input upto 100 S/s/channel, meaning 100 Hz, which is not in the kHz range that you wanted.
What kind of signals are you trying to acquire?
Kameralina
(7,010 Views)
This is a duplicate post that was answered here
Please try to only post on one board as it keeps our community less cluttered. Thanks!
PBear
NI RF
(7,005 Views)
