Dynamic Signal Acquisition
How to play an adquired waveform
I am using labview 6.1 to adquire signal form some acelerometers. What I'd want to do now is to play as if they were sound. ¿does anyone konw whether is it possible?
thaks
(6,934 Views)
The Sound and Vibration Toolkit has LabVIEW examples that acquire data from DAQ devices and save the data to WAV file format. The Getting Started example reads data from WAV files, performs measurements, and plays the WAV file through the sound card.
Doug
Enthusiast for LabVIEW, DAQmx, and Sound and Vibration
(6,931 Views)
you can also check the examples provided with LabVIEW (launch the Example Finder at the Help menu, and do a search for "sound"). You'll find several examples that make use of the Sound palette (Snd Play Wave File.vi, Snd Write Waveform.vi, etc..). BTW, I'm using LabVIEW 7.1 Professional, I'm not sure if your version includes these examples and functionality.
Jorge M.
Mensaje editado por Jorge M.
(6,921 Views)
