01-08-2004 05:44 PM
01-09-2004 11:20 AM
01-09-2004 01:08 PM
01-09-2004 05:34 PM
01-09-2004 06:23 PM
04-12-2004 09:13 AM
09-01-2008 12:50 AM
Hi. I am using the NI USB-6212 and I was having the same issue as well.
I've tried one of the solutions which was ground all unused channels and it did solve my problem. But I was wondering if there is a more elegant way to solve this issue rather than having 12 colorful wires (15 Analog Input, I'm using 3/15) bunched up into the AI GND?
Thank you
Ryan
09-02-2008
09:14 AM
- last edited on
11-10-2025
12:15 PM
by
Content Cleaner
Hi Ryan,
Grounding your channels will ensure that your signal is not floating above or below your ground reference. You can choose which channels to include in your task to avoid the open channels if that is a possibility for your application. Including the 3 channels you need into your task and not measuring the rest of the channels would work around the issue.
Incorrect Readings when Scanning Unconnected or Open Channels
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P6TeSAK&l=en-US
01-28-2009 11:06 AM
Dear National Instruments Engineer..
i want to plot the 3 phase phasor diagram, acquired from NI-DAQ 6008 which connected to 3 phase voltage source..
How to measure the phase angle of each voltage (relative to other phase)?
what should i do with the dynamic data wire? should i convert it to array? or other specific data type?
can you guys help me? please...
09-27-2010 06:07 AM
i am trying to acquire voltage and current value from analog input AI0 and AI1 sample channels.
but why does the DAQ read both de current and voltage values all the same?
