Dynamic Signal Acquisition
I having trouble installing device driver ref. cd's on windows XP 64 bit OS
I recently purchased labVIEW 8.2.1 and the sound and vibration toolkit.  The DAQ unit I have is the ni-9233USB.  I 've got a couple of options as far as computers that I can load the software onto.  The computer that I would like to use is my laptop, but I have the windows XP 64-bit operating system.  LabView seemed to install fine, but when I try to install the device driver reference cd's, it tells me they are uncompatible with the 64 bit OS.  I was curious if NI had driver cd's or a solution that is compatible with the 64 bit OS?
(7,301 Views)
Windows XP 64-bit is not a supported OS for the drivers and while LabVIEW may install it's actually not supported either. Vista 64 bit is supported, and you'll want to make sure to be using the most recent version of DAQmx (v 8.5) as well as LabVIEW 8.2.1.
Hope this helps,
Andrew S
National Instruments
(7,292 Views)
