Dynamic Signal Acquisition
I need build a adquisition system for PDA- pocket pc
We don't have a posket PC project.  The USB 9233 works for our applications/
Message 11 of 14
(4,432 Views)
Hello Nitin,
We offer some hardware that have built-in low-pass filters such as the PCI-6281 but no DAQCard options.  We have external options such as SCC or SCXI for filtering as well.
Laura
Message 12 of 14
(4,415 Views)
Hi Laura,
I have PXI 4472, PXI 4472 B and PXI 4462 which has built in low pass filters in them, but I was looking for a solution for DAQcard-6036E if there was any such hardware for that specific card. As I have two of them and wanted to sync both the cards, but if no hardware is present to anti-alias that specific card then I wont spend my time building an application around that card. We had those cards in spare where we needed sampling rate more than 96Khz. For other applications we use PXI cards.
I also talked to one of the Tech Sales representative yesterday about this thing and he also said that there is no such option available, so I am dropping the idea of making an application using these cards.
Thank you for your response
Nitin
Message 13 of 14
(4,413 Views)
Hello Nitin,
If you are using this DAQCard in a PDA, then it is correct that there is no hardware that can provide anti-aliasing filtering.  You hadn't mentioned anything about a PDA, so I wasn't sure if you were or not.  If you are not, then the SCC and SCXI options above would work if you are interested.
Laura
Message 14 of 14
(4,391 Views)
