Dynamic Signal Acquisition
Lock in amplifier phase lock trouble
Hello all,
     I've been trying to use a modified version NI Lock-In Startup Kit on some pretty simple AC signals. The VI is grabbing the signals from the DAQ card I have my PC hooked up to, I've been getting a frequency lock on the signals. However the phase and X-Y components seem to be all over the place. It's been kind of hard to troubleshoot the problem since I can't look at the PLL, demodulator and filter code. If anyone knows how to solve this and get a phase lock, that would be great.
     Grant
(6,894 Views)
scratch that, solved the problem.
(6,892 Views)
Hi Grant,
If you wouldn't mind, can you post what the solution to this issue was? That way, if someone with a similar issue searches in the future, they will benefit from your resolution.
Mallori
Mallori M
Sr Group Manager, Education Services
ni.com/training
(6,886 Views)
I was testing the lock in amplifier (LIA) to see if it worked, and I was passing it signals from two function generators, one as a test signal the other as a reference. I thought to simulate real world, less than optimal conditions I could use two slightly different frequencies. It locked onto the test signal frequency, but the phase was all over the place. I realized that this was because of the frequency difference, which was probably a little bit too large to simulate real world test conditions that I would be using the LIA in. So I just made the frequencies from the function generators the same, and it began locking onto the phase difference. It was more a question of understanding how to work the LIA than a coding problem. Hope this helps.
(6,882 Views)
