Dynamic Signal Acquisition
NI-4461+Signal Analysis
As brought out by you the tutorial at following link
http://zone.ni.com/devzone/cda/tut/p/id/4278    provides the formula for  calculating the frequency Response.
H(f) =cross power spectrum(A,B) / Power Spectrum(A)
where
cross power spectrum  =FFT(B)XFFT*(A)    and   power spectrum  =FFT(A)XFFT*(A)
                                                 N^2        N
i have two questions
1) is FFT(B)XFFT*(A)  the convolution of FFT(B) and FFT*(A)  ?
2) The  cross power spectrum results in a complex array.Similarly the power spectrum results in a complex array.Now how do I divide one complex array by another complex array?
Sorry I am going a bit mathematical.But the option at present is to implement it in code.
Bhaskar
Message 11 of 13
(3,914 Views)
Hi Bhaska,
To my knowledge, this is not a covolution and simply a multiplication. As far as performing the mathmatics in code, I would recommend posting to either the Measurement Studio board or on a C developers forum such as on MSDN. I say this as this thread has turned from a DAQ/Hardware thread into a software implementation of mathmatical principles and you would get better support going those routes.
In the meantime, I suggest searching many of the online mathematics resources available on the web.
PBear
NI RF
Message 12 of 13
(3,885 Views)
Hi Patrick,
Thanks for all the support.U may be right in saying that this a DAQ Hardware/Labview forum.Maybe I'll have to search somewhere else for signal processing implementations.
Bhaskar
Message 13 of 13
(3,874 Views)
