Dynamic Signal Acquisition
NI4472 & SMB110 cable
My question is very elementary. I have a NI4472 and using SMB110 cables. Is there a connecter box which can be used as interface between ordinary wires and BNC connections?
(6,705 Views)
Ali, I don't know of any connector. I use a metal project box with male BNC on one side and banana plugs on the other for the wires. The connectors I bought all have solderable connections and were soldered together in the box.
(6,703 Views)
You can purchase BNC to clip lead and BNC to binding post adaptors from several connector vendors and also do the same for box mounted adaptors. The box mounted adaptors typically allow you to add external components inside the box if desired.
(6,705 Views)
