Dynamic Signal Acquisition
what is a AT-A2150?
I found a AT-A2150 board in our labs and want to know if it's valuable. If it is, is there simple software (besides labview) to us it? Many thanks.
(6,844 Views)
Hi Foodeng,
The AT-A2150 is an old Dynamic Signal Acquisition board that was discontinued in December of 1999. You can read the Discontinuation Notice online at http://digital.ni.com/manuals.nsf/webAdvsearch/65920414414687FE8625678D0056B8B2?OpenDocument&vid=niwc&node=132100_US. According to the Data Acquisition (DAQ) Installation/Configuration Troubleshooter at http://www.ni.com/support/daq/versions.htm, this board requires NI-DAQ 4.9 and Windows 95. Of course, if you use an old version of NI-DAQ, you will also need to use an old version of LabVIEW. I do not recommend trying to use this board, but if you must, you can download old versions of NI-DAQ at http://digital.ni.com/softlib.nsf/webcategories/85256410006C055586256BBB002C1293?opendocument&node=132
070_US. For more information on this board, I recommend reading the User Manual. You can find it at http://digital.ni.com/manuals.nsf/webAdvsearch/9EDE6D8353864B0C862567D20067FACD?OpenDocument&vid=niwc&node=132100_US. I hope this answers your questions.
David Shatila
(6,844 Views)
Thank you for the quick and thorough response.
sincerely,
Brian Heskitt
(6,844 Views)
