Dynamic Signal Acquisition
Problem resolution
When trying to build an executable I get this error message (in red the messages):
The following files have links to help files that are invalid. Open the files and fix the help links.
C:\Program Files\National Instruments\LabVIEW 8.0\vi.lib\addons\NISVL\_NISVL.llb\svl_Caller VI Returned in Error Source.vi
C:\Program Files\National Instruments\LabVIEW 8.0\vi.lib\addons\NISVL\_NISVL.llb\svl_Extract Scale Factor.vi
C:\Program Files\National Instruments\LabVIEW 8.0\vi.lib\addons\NISVL\_NISVL.llb\svl_Modify Enhanced Spectrum Info (Dual).vi
C:\Program Files\National Instruments\LabVIEW 8.0\vi.lib\addons\NISVL\_NISVL.llb\svl_Extract Unit Label (enhanced spectrum info).vi
C:\Program Files\National Instruments\LabVIEW 8.0\vi.lib\addons\NISVL\_NISVL.llb\svl_Unit Label Lexical Class.vi
C:\Program Files\National Instruments\LabVIEW 8.0\vi.lib\addons\NISVL\_NISVL.llb\svl_View Phase.vi
C:\Program Files\National Instruments\LabVIEW 8.0\vi.lib\addons\NISVL\_NISVL.llb\svl_Enhanced Spectrum Units.vi
C:\Program Files\National Instruments\LabVIEW 8.0\vi.lib\addons\NISVL\_NISVL.llb\svl_Build dB Label from Weighting and Ref.vi
then in the Details section:
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a reference:
Error 7 occurred at ABAPI Check Help FIles.vi -> ABAPI Dist Cmp Settings to Disk Hier.vi -> ABAPI Get Settings From File.vi -> EBEP_Invoke_Build_Engine.vi -> EBUIP_Build_Invoke.vi -> EBUIP_Build_Rule_Editor.vi -> EBUIP_Item_OnDoProperties.vi -> EBUIP_Item_OnDoProperties.vi.ProxyCaller
Possible reason(s):
LabVIEW:  File not found. The file might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. For example, use \ as path separators on Windows, : on Mac OS, and / on Linux.
I do not understand what to do - can someone explain me in simple steps how to build the executable? the vi works fine (so I assume all components are installed properly)
Cheers,
Dimitris
(6,930 Views)
Hi Geophysics,
This is a known issue that has been fixed in later versions of LabVIEW and the Sound and Vibration Toolkit.
Jared T.
(6,910 Views)
