Dynamic Signal Acquisition
Real Time Analysis of data from DAQ assistant
I'm using USB 6009 with the DAQ assistant to acquire my data. I use 2 channels on the USB 6009, Channel 1 is a square wave that goes from -5 to +5 V (2.3 Hz, 5k sampling rate; 1000 samples); Channel 2 is a bio-potential that is being recorded (5k; 1000 samples).
My channel 2 data is dependent on the transition of the square wave from -5 to +5 or vice versa. (i.e - every time a sign change occurs in my square pulse - a change occurs in my bio potential)
My goal is to detect this sign change and its corresponding change in the bio-potential (Ch2), ultimately leading to a matrix of "chopped windows" of bio-potentials (i.e - each sign change in channel 1 = 1 column of bio-potential in matrix built).
Approach:
I managed to identify the indices of sign change form positive to negative and vice versa and put it in a queue. I want to access the bio-potential at the indices obtained above, in order to chop a 1000 point window of  bio-potential - i.e biopotential(index -250:index+750); and ultimately populate a matrix.
But am unable to do that.
Issues:
1. How do I consume channel 2 queue while consuming channel 1
2. Consumed data in queue did not seem to match the input order.
3. I think the way I am synchronously running multiple loops is incorrect - As I don't see what I am expecting to see.
4. How do I keep track of channel 2 index while consuming it from a queue?
5. Is there a better approach for all of this? - Am I missing something?
- Labview Version 2012; DAQ is replaced by Simulate signal for testing purposes.
Attached is my VI. Help is much needed and appreciated!
Thanks!
(4,481 Views)
What exactly are you having issues with? It looks like you are de-queuing from each respective queue in the loops. Can you clarify what functionality you hope to achieve?
Queues work as a FIFO buffer; meaning that the first element you enqueue will be the first element de-queue. Is this not the order you are seeing?
What are you expecting to see?
I am not sure what you mean by the channel 2 index. However, the iteration index of the loop can tell you how many times the loop has run; Effectively telling you how many elements have been de-queued
Once we have a better picture of what you are trying to do, we may be able to help you set up a better architecture
(4,433 Views)
