Dynamic Signal Acquisition
Vuvuzela-filter
is there anybody out there, who has programed a Vuvuzela-filter using a conventional soundcard?
transfererror
(9,590 Views)
I only found how to do it with a mac.
Can this be done also with Labview?
http://www.surfpoeten.de/tube/vuvuzela_filter
(9,569 Views)
Accepted by transfererror
(9,541 Views)
Great and just in time for Germany's next match tomorrow.
Thank you
transfererror
(9,529 Views)
I installed the runtimeversion on a XP-computer.
Then i started the exe-file.
But error-popup:
LABVIEW: Ressource nicht gefunden
Beim Laden des VIs "NI_AALPro.lvlib:Unwrap Phase.vi" ist ein Fehler aufgetreten.
Labview-Ladefehlercode 3: Frontpanel konnte nicht geladen werden.
then i pressed OK and then then aother popup with nearly same message ".... NI_AALPro.lvlib:Power Spectrim (DBL).vi
...."Real FFT.vi
...."Scaled Time Domaoin Window.vi
Whats wrong here?
Thx
Message Edited by OnlyOne on 06-17-2010 02:47 AM
(9,523 Views)
After also installing the 30days evaluation + the patch-f3 the exe-file is working.
(And the 30days version is registered somehow as fullversion without entering any keys.
There popped up a message if i want to use a "found" key, but i didnt read all the messages in detail
just clicked next, next, next...... and at the end it said registered.)
(9,501 Views)
OnlyOne,
When you unzipped the exe did you also unzip the data folder with the two .dll files?
It sounds like the exe wasn't able to find the analysis library until you installed LabVIEW.
~Simon
(9,479 Views)
