Dynamic Signal Acquisition
What are the limitations and maximum cable lengths of icp microphones
We are setting up a system to use multiple ICP mics. Any idea about the limitations of icp vs. condenser mics for free field measurements? What are the max cables runs for icp mics. I was under the impression that the bandwidth is limited at runs over 10 m.
(6,481 Views)
From PCB's website: http://www.pcb.com/techsupport/tech_cables.aspx
�While there is virtually no increase in noise with ICP sensors, the capacitive loading of the cable may distort or filter higher frequency signals depending on the supply current and the output impedance of the sensor. Generally, this signal distortion is not a problem with lower frequency testing within a range up to 10 000 Hz. However, for higher frequency vibration, shock or transient testing over cables longer than 100 ft. (30 m.), the possibility of signal distortion exists.�
Hope this helps.
Ian Ren
Roush Industries, Anatrol Division
(6,481 Views)
