Dynamic Signal Acquisition
how I can correctly use the VIs of calibration of LabVIEW?
I have a NI 4472 card and need to develop a software to calibrate an accelerometer, but the VI that I'm using show me an error
(6,765 Views)
Does the accelerometer that you want to calibrate require a constant current excitation (ICP or similar)? If it is the case the calibration VI does not provide a way to turn on ICP on the 4472. You will need to do a separate call to AI Parameters.
(6,765 Views)
I already makes the modifications to call configuration AI separately and now it marks the error -10003
(6,765 Views)
Would you mind posting your code? You can also email it to me directly at thierry.debelle@ni.com. That should help us to make progress faster. Thanks in advance.
(6,765 Views)
