Dynamic Signal Acquisition
cal-bay vibDAQ NI h/w list?
hi all,
cal-bay vibDAQ works with NI 9234/9215A, NI PXI-4472, NI PXIe-4497, and others...
i need the complete list of ni h/w (ni equipments) that can be used with.
is usb4432 included?
thanks
Masood
(7,862 Views)
Hello Masood,
vibDaq currently works with the following supported hardware:
NI 9233 in USB or cDAQ
NI 9234 in USB or cDAQ
PCI-4472
PXI-4472
PXIe-4497
PXIe-4499
Though it currently does not support the USB-4432 or USB-4431 Cal-Bay and National Instruments recognize that as a customer need and are making it a priority to add support for those two products.
Doug Farrell
Solutions Marketing - Automotive
National Instruments Automotive Solutions
(7,860 Views)
thank you Doug Farrell,
i have PCI-4472B instead of PCI-4472.
so will it work with PCI-4472B as well?
thanks
Masood
(7,842 Views)
Accepted by m_tahir_m
Should have no problems there, I should have specifically called out the 4472B variant.
Doug Farrell
(7,819 Views)
